It is currently Thu Aug 21, 2025 5:37 pm
PostPosted: Sat Aug 03, 2013 8:52 am
To cut channels for fine lines of purfling, are most people using their laminate trimmers with a collet for 1/8" shaft bits, or are you using a dremel and no collet with the smaller bits?
I'm curious b/c I'm about to cut some fine lines, need to get set up, and could go either way.
TIA,
Ken Mitchell
Durham, NC
PostPosted: Sat Aug 03, 2013 8:58 am
If you are referring to rosettes, I use a collet in a laminate trimmer. I bought it from either StewMac or LMI; don't remember which. I no longer use my Dremel for that type of work.
PostPosted: Sat Aug 03, 2013 11:40 am
First name: Raymond
Last Name: Pipkin
I'd been using my dremel with a shop made circle jig, then switched to the stewmac circle jig. It works good if I'm careful. But I think I'll switch to my little router soon as I make a circle jig for it. It's a lot heavier and more stable and just more pleasant to use than the dremel.
PostPosted: Sat Aug 03, 2013 11:48 am
First name: Raymond
Last Name: Pipkin
Oh, also an example of why I think heavier is better, on my last build I used the dremel setup. It worked great except I wasn't paying attention to the cord and let it pull the dremel just slightly out of vertical. This shifted the bit and cut the channel too wide in one spot. I was able to fill and you can't really see it, but it wasted some time.
PostPosted: Sat Aug 03, 2013 12:35 pm
The laminate on the Wells-Karol circle jig works very nice and is rock solid.
PostPosted: Sat Aug 03, 2013 4:51 pm
Last Name: Beaver
City: Lake Forest
Laminate trimmer with a circle cutter here. To much wobble in the dremel
Joe Beaver
Maker of Sawdust
PostPosted: Sun Aug 04, 2013 12:42 am
I've been using my drill press circle cutter. I have a blade that's one thin purfling line thick. I haven't found a router bit that fine.
I bought a Wells/Karol jig and haven't used it yet.
Looks like a neat device though!
Old growth, shmold growth!
PostPosted: Sun Aug 04, 2013 11:16 am
Thanks for all the responses. I've got a collet to step down from 1/4 to 1/8", and I've got the cirlcle jig for the router. From the responses, that would seem to be the preferred method. Now I just need to get a couple more of the smaller router bits that are available.
Ken Mitchell
Durham, NC
PostPosted: Sun Aug 04, 2013 12:57 pm
Last Name: Tulloch
State: Vermont
I use the Cordless Dremel.....frees me from the cord in a twist problem. Goes smooth for me.
PostPosted: Sun Aug 04, 2013 10:11 pm
First name: Tony
Last Name: C
City: Brooklyn
I have a Bishop Cochran base, Bosch colt laminate trimmer and I use .25" shank bits. I have 1/16th inch bits with .25" shafts. I think I got them from amazon.com.
Sent from my iPhone using Tapatalk 2
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Aug 04, 2013 11:55 pm
First name: nick
Last Name: dingle
I tossed my home-made circle cutter, used with the dremel plunge router base. ($45 of useless, that base) and bought the Stew Mac circle cutter, but have also bought a laminate trimmer, so may change again in the future. I hang the cord of the dremel, and all my power tools from a hook over my workbench. Well, ever since a rather unfortunate accident... [headinwall] Alsobought 50 end mills on eBay, delivered, from Texas to Australia for $51AU
They range from 1/32" to 1/8". More than I need this week.......
PostPosted: Mon Aug 05, 2013 9:35 pm
I can never find anything easy to find. I need some small router bits to inlay a flamingo into a headstock.
What's PMT?
PostPosted: Mon Aug 05, 2013 10:22 pm
Last Name: G
Hmmm. I googled PMT router bits and found this:
http://www.pmtnow.com/end_mills/tools/TR-2.asp
No idea which style Todd uses, as there are a bunch of different pages/styles.
cheers
PostPosted: Wed Aug 07, 2013 4:00 pm
First name: Joshua
Last Name: Janssen
LMI Circle cutter
PostPosted: Wed Aug 07, 2013 9:59 pm
First name: Danny
Last Name: Vincent
cheers
Ouch on the prices! These guys don't have as big of a selection but much better pricing. http://www.bqtool.com/ The metric can be good sizing for some purfling.
PostPosted: Wed Aug 07, 2013 10:35 pm
Todd Stock wrote:
Router bits - really end mills for drilling and routing electronic components - are easy to find in widths down to .010...for the thin single line ring using .020 stuff, .021 works...most veneer is around .022 to .024, so a .025 works. My former fav place for end mills has packed up and moved/gone bankrupt, so try the usual suspects (PMT, etc.) and pick up a 1/4" to 1/8" collet reducer.
Wells-Karol jig...micro-adjust in thousandths and rock solid.
Ya, what he said ;)
http://www.amazon.com/gp/aw/d/B000N4571 ... -1&pi=SL75
Check out this amazon store for other end mills too.
Users browsing this forum: TripodBob and 15 guests
